It is currently Tue Aug 05, 2025 4:23 am
PostPosted: Tue Nov 03, 2009 10:50 pm
I'm looking at mounting a lightweight bonnet with four quick release pins.
http://www.minisport.com/acatalog/info_LMA240.html
Where do folks put their pins in the body?
I'm thinking the rear might need a couple of plates welded across the rear corners somewhere but there is probably enough flat steel on the front.
Suggestions?
Pictures of how they are mounted if possible would be appreciated.
Regards,
Mike
"He who dies with the most toys wins."
PostPosted: Tue Nov 03, 2009 10:52 pm
4x small diagonal plates welded (or bolted) into the 4x corners of the bonnet opening area
PostPosted: Wed Nov 04, 2009 11:55 am
I use four of these type sliding pins to hold the f/g bonnet down on the van. I cut four triangle shape alloy plates and riveted them to the drain channel on the wings and front / rear panels.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
 Post subject: Bonnet
PostPosted: Wed Nov 04, 2009 7:55 pm
Balrick: "There is a subtle flaw in your plan my Liege."
Blackadder: "And what exactly is that Baldrick?"
Baldrick: ""It's crap.""
I should have said that I have a Clubman.
Front and rear corners have more bits when compared to roundnose:
Front:
Rear:
Anybody added a fibreglass bonnet onto the front of a Clubman and can advise on how they fitted the pins?
Regards,
Mike
PostPosted: Wed Nov 04, 2009 9:44 pm
Mike, the last cluuby we had here with a lift-off bonnet had pins straight through the original tin, at the outer corners. The bonnet was spaced 'up' by bits of hose over the pin, and held down with R clips.
Front was done just in front of where your compliance plate goes, but before the double panel.
PostPosted: Wed Nov 04, 2009 9:48 pm
oops,,, should have known by your avitar pic thingy
yeah corners are sweet & ready for a drill ,,, fit the pins, mark & drill the bonnet to suit,,, pack with small rubber bush & Bob`s your Aunty,,, er sorry,,, that should be Bert`s your Aunty now :-)
PostPosted: Wed Nov 04, 2009 9:53 pm
I'm also looking at doing this procedure to my bonnet on my clubby, so any information regarding on the mounts would be much appreciated.
Sav
73 Clubman - Working Progress
PostPosted: Thu Nov 05, 2009 5:23 am
here's one we prepared earlier .....
michael
PostPosted: Thu Nov 05, 2009 6:53 am
droool
Copper 4 lyfe!
PostPosted: Thu Nov 05, 2009 9:33 am
Agreed. That is one HOT clubby.
PostPosted: Thu Nov 05, 2009 10:14 am
Kinel - thats bootiful....
It looks like you've just done what I am about to start.
Pm to follow! :D
Regards,
Mike
PostPosted: Fri Nov 06, 2009 5:16 am
MORE details to come later ...
PostPosted: Fri Nov 06, 2009 5:58 am
:shock: there's a lot going on in that engine bay! yes build details please!
..steering wheel is on the wrong side though :P
Users browsing this forum: ClubmanGT and 104 guests
