mtsmini wrote:
1. Did the classic mini and the clubman have the same doors and are they interchangeable?:
Morris mini's had the same external hinges but the doors and more particularly the door catch mechanism are different . To use Morris or Australian non clubman door handle doors in a clubman style shell you'll need to cut the B pillar from a Morris .
mtsmini wrote:
2. Do all doors have the inside lower boxes? I seem to have seen some that are just plain with flat insides.
All Australian and earlier type doors have the door pockets , the only ones that came from the factory without door pockets were the later Rover type or UK type 3 or later mini's . These are all the ones with internal door hinges . All external door hing doors had the pockets from the factory .
Also , since we're talking doors , the internal hinged doors won't fit Australian (external hinged) doors , they are a different shape at the front and back edges .
