original rear trumpet
https://www.ausmini.com/forums/viewtopic.php?f=2&t=58315
Author:  niffty64 [ Thu Oct 29, 2009 6:39 am ]
Post subject:  original rear trumpet
I want to keep the original rear trumpet they are in good condition. What i want to know is do i refit the spacer ring between trumpet and new ball joint ?
Author:  GT mowog [ Thu Oct 29, 2009 7:12 am ]
Certainly on the front, I've found that the spacers were factory fitted in the 'latter' cars. On the rears, some did and some did not and there were different thickness washers. I can only guess that it was used as an adjustment point by way of shimming.
All the parts book says is 'As Required'.
Author:  niffty64 [ Thu Oct 29, 2009 7:14 pm ]
these spacers were on the rear but not the front suspension. ????
Author:  GT mowog [ Thu Oct 29, 2009 8:04 pm ]
It may be an 'earler' car prior to them being fitted or it may have been gotten at before you bought the car. I noticed that in the very late english cars they actually use a different knuckle joint that has the spacer built in.
Author:  niffty64 [ Thu Oct 29, 2009 8:12 pm ]
thanks GT mowog
I will just try refitting the spacer ring as it was in the car. i dont realy understand if this will lift the car or harden the suspension. i have new rubbers to fit as well. i dont realy have all the information. so i hope someone here can help
Author:  Morris 1100 [ Thu Oct 29, 2009 8:18 pm ]
It is there to lift the car. It does nothing to harden the suspension.
Author:  david rosenthal [ Fri Oct 30, 2009 12:48 am ]
my english made 60 car has the welded rear swing arms and trumpets without the spacer washers. both of the 850,s that have the later cast swing arms with the welded trumpets have spacers.
There could have been a difference in the swing arms and the spacers were used to get the correct ride height with the welded trumpets
Author:  850 GT [ Fri Oct 30, 2009 7:00 am ]
Are these welded trumpets getting hard to find or are they still around, i have a set that i am not going to use. are they worth anything?
Author:  niffty64 [ Fri Oct 30, 2009 7:52 am ]
Thanks guys
My feel is if they were there in the first place replace them.
"Are these welded trumpets getting hard to find or are they still around, i have a set that i am not going to use. are they worth anything?"
I dont know if they are worth anything. i know they are rare to find. I want to keep everything i can that is original if its in good nic.
Author:  Timbo [ Fri Oct 30, 2009 8:08 am ]
Yes to a restorer they are very valuable. I don't know what you'd be able to sell them for though.
