It is currently Sun Jul 27, 2025 11:29 pm
 Post subject: Removing Door Skins
PostPosted: Thu Oct 29, 2009 8:30 am
I have a new bullet mirror I need to fit, but I can't figure out how to remove the door skin :oops: It seems like something that should be simple, so I feel a bit stupid...
I unscrewed everything, but the skin wouldn't budge.
PostPosted: Thu Oct 29, 2009 8:38 am
Errrr.... why to you need to remove the door skin to fit a mirror?
The skins are virtualy fixed - edges folded over a a few spots of weld to lock them on.
PostPosted: Thu Oct 29, 2009 9:29 am
you'll have to take off the handles on the inside as well. if there aren't any screws left in it may have been glued down?
1962 850,Frog
PostPosted: Thu Oct 29, 2009 9:34 am
I think he means door trims
 Post subject: Re: Removing Door Skins
PostPosted: Thu Oct 29, 2009 10:01 am
Sorry I understand that it is a personal choice, but why would you want to fit bullet mirrors? Have you ever actually tried to use them? as a mirror I mean.
To take the Trim off from where you are now, there are a couple of hidden lift clips at the trailing edge (or back edge) of the trim, usually a steel rule slid under the card and gently lifted will get the job done.
There is a chance that someone has used adhesive as well.
Great Mo by the way :)
