Removing Door Skins https://www.ausmini.com/forums/viewtopic.php?f=2&t=58319 |
Author: | moustache [ Thu Oct 29, 2009 8:30 am ] |
Post subject: | Removing Door Skins |
I have a new bullet mirror I need to fit, but I can't figure out how to remove the door skin ![]() I unscrewed everything, but the skin wouldn't budge. |
Author: | Wombat [ Thu Oct 29, 2009 8:38 am ] |
Errrr.... why to you need to remove the door skin to fit a mirror? The skins are virtualy fixed - edges folded over a a few spots of weld to lock them on. |
Author: | EAB [ Thu Oct 29, 2009 9:29 am ] |
you'll have to take off the handles on the inside as well. if there aren't any screws left in it may have been glued down? |
Author: | awdmoke [ Thu Oct 29, 2009 9:34 am ] |
I think he means door trims |
Author: | GT mowog [ Thu Oct 29, 2009 10:01 am ] |
Post subject: | Re: Removing Door Skins |
moustache wrote: I have a new bullet mirror I need to fit, but I can't figure out how to remove the door skin
![]() I unscrewed everything, but the skin wouldn't budge. Sorry I understand that it is a personal choice, but why would you want to fit bullet mirrors? Have you ever actually tried to use them? as a mirror I mean. To take the Trim off from where you are now, there are a couple of hidden lift clips at the trailing edge (or back edge) of the trim, usually a steel rule slid under the card and gently lifted will get the job done. There is a chance that someone has used adhesive as well. Great Mo by the way ![]() |
