It is currently Tue Jul 29, 2025 1:07 am
PostPosted: Thu Oct 29, 2009 2:52 pm
Hi Guys,
after spending some time figuring out why my mini reeked of oil, I decided to write this up to shed some light on this mysterious system.
What is PCV?
It is a system for venting crankcase pressure. If not vented properly, the crankcase becomes pressurized due to blow-by past the piston rings during combustion. Piston rings never seal 100% even when new, and the problem only gets worse with age. The word positive is used to mean active rather than passive; in fact, it's purpose is to keep crankcase pressure slightly negative (equal to intake vacuum). Historically, crankcases have been passively vented.
Why do I need it?
It is the difference in pressure between the cylinder and crankcase which causes the piston to move and do work. If the crankcase is poorly vented, the pistons cannot move as freely and you are wasting engine power to overcome crankcase pressure. Proper crankcase ventilation:
- Improves idling and revability
- Increases engine power
- Reduces incidence of oil leaks as oil isn't being forced out of seals under pressure
- Reduces oil sludge-ification by removing hydrocarbons from the crankcase
- Reduces hydrocarbon emissions by burning the crankcase vapours
How does it work?
The PCV system is an open system. It is not recirculating gases, but maintaining a constant stream of fresh air through the crankcase. In practice, this is done by using intake vacuum suction.
Yes, this implies that outside air is entering your crankcase from a source other than your air filter! It either comes from your charcoal canister, or a vent filter.
The reason the PCV system is so confusing to understand is because it is mixed up with the emissions control system (charcoal canister) and carburetion/intake system. The only reason it's connected up that way is because it's convenient.
What is a PCV valve?
The PCV valve's job is to make sure that air can flow out of the crankcase, but not back in. Not all mini configurations use one because
a) they have a flame trap to catch backfires
b) intake pressure on that car is always lower than crankcase pressure.
It's secondary function is to control the rate of air flow, by restricting the orifice and/or opening a breather orifice.
Wikipedia Article
OK, how is it supposed to be connected up?
Based on the number of different configurations I've seen on this site and 2 different workshop manuals, I'd say there are only a bazillion different ways. I'd say just try to understand how your mini is setup.
1978 Leyland mini
Charcoal canister: 3 inputs at the top, and one vent at the base. Big centre input at the top connects to rocker cover input. This is where fresh air is fed to the crankcase. The charcoal is effectively the filter. The two small inputs on the sides are 1. Fuel tank vapours and 2. Vent (Is this supposed to go somewhere??)
There is a flame trap just next to the radiator-side engine steady bar. It is a cylindrical thing mounted to an engine cover plate. It contains a gauze to trap oil leaving the crankcase, and prevent a backfire from the intake getting into it. The outlet at the top should be connected to a vacuum port on the carby.
That's it! I can't believe the complicated plumbing I pulled out which the PO rigged up to fumigate the cabin! :x
Feel free to contribute your setup! Please be as descriptive as possible because it is confusing as hell! Also, let me know if there are any mistakes/omissions.
hg.
PostPosted: Thu Oct 29, 2009 3:29 pm
all hail the "Evacupan system"
sorry,,, i like throwing spanners :-)
PostPosted: Thu Oct 29, 2009 3:43 pm
hg.
I think this is a great little article about one of (probably) the most mis-understood systems in the mini :shock: Good on ya headgasket :D :D
The 2. vent above actually connects the the fuel bowl vent.
PostPosted: Thu Oct 29, 2009 4:03 pm
Ok.....ive seen the fun, wheres the profit :wink:
PostPosted: Thu Oct 29, 2009 5:02 pm
Supercharged
what do ya do when you dont have the tappet cover vent? use the clutch vent?
PostPosted: Thu Oct 29, 2009 5:16 pm
Vents were fitted to four different places depending on the model (rocker cover, timing chain cover, tappet chest cover and primary gear/clutch cover)
On a road motor in good condition you only need one vent to be hooked up properly for the system to work.
On a race motor that is breathing into a catch tank the more breathers the better.
PostPosted: Thu Oct 29, 2009 7:51 pm
Did someone mention "Engine breathers"?????
lots of big ones here :-)
But it`s only a 1600cc with 13.8:1 compression ratio & 764 cam :-)
PostPosted: Thu Oct 29, 2009 7:54 pm
A great ad for Goodyear Ortac hose right there..
PostPosted: Thu Oct 29, 2009 8:53 pm
Must have very bad bore surface prep hey?
PostPosted: Thu Oct 29, 2009 8:57 pm
Needs more failsafes Matt.
PostPosted: Thu Oct 29, 2009 8:58 pm
This space for rent
:lol: :lol:
You guys...
PostPosted: Thu Oct 29, 2009 10:39 pm
That engine is not breathing, it's hyper-ventilating :o
www.minisprintgt.com
PostPosted: Fri Oct 30, 2009 9:12 am
So why do twin 1.25 SU's use a PCV valve but a 45 Weber doesn't?
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri Oct 30, 2009 9:24 am
You need proper vacuum for a PCV valve to work, and you won't get that with a weber.
PostPosted: Fri Oct 30, 2009 9:52 am
Not true, I have a PCV with a 45 Dellorto and it works fine.
It is now on a tiny balance pipe so that my idle mixtures are even, but it worked just fine without that before. :wink:
