It is currently Sat Aug 02, 2025 5:06 pm
PostPosted: Thu Oct 22, 2009 1:58 pm
After a good run on the weekend, the mini has developed a mystery miss again.
It sounds &feels like it is running on 3 cylinders when idling (Rough and irregular engine sound) and when not under load. Put your foot down and the miss goes, and all the power is there.
What should I be looking at that may cause this ?
Would an earth strap with a fairly frayed engine block end have any effect ?
PostPosted: Thu Oct 22, 2009 2:21 pm
The only thing I can think of it being on you car would be plugs or leads.
The injection should take care of everything else, that is if theres a problem it (inj), it would be all wrong or nothing.
PostPosted: Thu Oct 22, 2009 2:53 pm
Tomboss Breweros
I'd be looking for a vac leak.
It will miss at idle, then on open throttle theres no vac therefore no vac leak and all will run well.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Oct 22, 2009 3:00 pm
Both the above are what id be looking for before going any deeper
PostPosted: Thu Oct 22, 2009 3:44 pm
check that the inlet manifold is actually tight
edit--> as in that it`s mounted properly---> all nuts/bolts are done up tight
PostPosted: Thu Oct 22, 2009 3:47 pm
I could remember something similar being posted before , not sure if it's the same issue but worth checking anyway ,
http://www.ausmini.com/forums/viewtopic ... ected+hose
PostPosted: Thu Oct 22, 2009 6:58 pm
Have a look through the section relating to SPI/MPI on TMF.
Has helped me with a few problems, there is a lot of good reading on there so make a cuppa have a read.
Cheers Pete
http://www.theminiforum.co.uk/forums/in ... wforum=140
PostPosted: Fri Oct 23, 2009 8:13 am
Thanks for the advice people!
I will pick up some new plugs this arvo, as I swapped back to an old set of leads and still had the same problem.
I will also pull off the hoses from the manifold/ecu also and give them a check over.
Now onto the uk mini forum for some 'light' reading :)
Thanks!
PostPosted: Sat Oct 31, 2009 4:12 pm
Turns out ALL the bolts holding the exhaust and inlet manifolds on the head were not done up.
I was able to do them up tighter with my fingers before I even touched them with the spanner.
Did the water mist trick after advice from local Mini workshop guy.
Users browsing this forum: No registered users and 70 guests
