It is currently Tue Aug 05, 2025 9:35 pm
 Post subject: HELP URGENT
PostPosted: Wed Oct 28, 2009 5:35 pm
hi all,
finally after a year of work my mini is ready back on the road,
had many issues with clutch getting everything right,
now I have a few wiring problems,
1.left hand indicator and park light stay on,
but a bigger one is car will not turn off via key.
my wiring diagram is usless,
does anyone have help for my reborn 76 leyland 998 in time for minifest tas on sunday.
PostPosted: Wed Oct 28, 2009 5:56 pm
Mods rock!
Sounds like you've got an 'intermix' between the 'live' wiring and the 'switched' wiring.
The 'live' stuff (If it's original) will be Brown (maybe with a trace) or Purple (may also be with a trace).
The 'switched' will be white (maybe with a trace) or green (maybe with a trace). I'd suggest having a good look at your fuse block first. Also check that there's nothing shorting between the fuses or the wires on the end.
Could also be your ignition switch, or something shorting on the back of that.
You may need to one by one start un-plugging some connectors until you find the 'dicky' one.
Have you got a lamp or meter you can use for some testing?
PostPosted: Wed Oct 28, 2009 8:07 pm
Take it to minifest anyways....When you need to turn the engine off just pull the white wire with the red trace off the solenoid and then turn the ignition switch off. Someone there may be able to rectify or trace the problem. :wink:
PostPosted: Wed Oct 28, 2009 9:00 pm
Mods rock!
........Or maybe the white one off the coil :wink: :wink:
(Sorry Ballistic - White / Red is the one for the solinoid coil to start it with)
PostPosted: Thu Oct 29, 2009 9:05 am
If you can get it to Minifest I'd be happy to have a look at it for you there, but I'm flat out trying to get my Traveller going so can't help much before. Send me a PM if you haven't got it worked out.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Oct 29, 2009 8:07 pm
well got it sorted,
some muppet put some wires on wrong way lol.
got a few more foibles to fix now,
new engine with new clutch and kad quickshifter,
im having to double pump or triple pump the clutch to get it in gear.
also ticking coming from i think alt belt to tight,
but thats easy fixed.
other than that no dash lights and brakes suck cuz i got new front disks but using standard old master cylinder
PostPosted: Thu Oct 29, 2009 8:45 pm
That shouldn't matter, unless the old m/c is no good. There shouldn't be any problem in using the m/c off a '76 drum braked car with disks.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Thu Oct 29, 2009 9:06 pm
the pedal just seems weak,
a little softer than what i thought new disk set up should be.
well me and the stage 3 kitted 1046 will still be at minifest,
just gotta find some mirrors and a washer bottle
PostPosted: Fri Oct 30, 2009 7:38 am
anyone in hobart got a set of mirrors they wanna part with
PostPosted: Fri Oct 30, 2009 6:53 pm
anyone know where to get some mirrors and a clutch master cylinder on a saturday in HOBART.
please please
PostPosted: Sat Oct 31, 2009 8:13 pm
just wanna say Wilson auto Kicks ass,
got my bits i need,
now just having clutch issues,
comes then goes.
gotta bleed it again i think.
cant find reverse though.
anyone got any ideas.
might be the kad shifter
