hey does anyone know this bolt size? https://www.ausmini.com/forums/viewtopic.php?f=2&t=58472 |
Author: | NG [ Tue Nov 03, 2009 7:33 pm ] |
Post subject: | hey does anyone know this bolt size? |
Accelerator bolt bracket that guids the Accelerator cable on twin su's I'm after that screws size into the manifold. I need size and length thanks ![]() They are 1 1/4 twins |
Author: | Mick [ Tue Nov 03, 2009 7:38 pm ] |
1/4" x 3/4 long UNC. Use a washer however, its a short blind hole. |
Author: | NG [ Tue Nov 03, 2009 7:41 pm ] |
Is there any difference between auz and english mainifolds? |
Author: | Mick [ Tue Nov 03, 2009 7:45 pm ] |
unsure, the thread I checked on my spare (cracked) stock BMC manifold had UNC. As it is botling a bracket onto aluminium, I wouldn't expect them to use anything other than UNC, as UNF will pull the fine thread out of the soft allow to easily. |
Author: | NG [ Tue Nov 03, 2009 7:51 pm ] |
I could buy both if the bolt shop sells them. |
Author: | NG [ Tue Nov 03, 2009 8:06 pm ] |
I think it might be a rover manifold? Any difference. I just don't have any bolts that fit. Can you tell me what that bolt is call might be able to check on mini spares. |
Author: | Mick [ Tue Nov 03, 2009 8:56 pm ] |
You will get them off the bolt rack at supercrap/ autobarn etc. I believe it will be UNC if it is ally, but by all means get a UNF equivalent if you need to be sure. No need to import it. |
