It is currently Mon Aug 04, 2025 2:49 pm
 Post subject: Casting Sand
PostPosted: Thu Nov 05, 2009 5:04 pm
Anybody else found a solid chunk of casting sand floating around your sump?
This lump was about the size 50 cent piece and about 1 cm high.
You think after nearly 40 years it would have fallen off before now. I had the sump off last year and all was well.
I pulled the gb housing/sump off because something was blocking oil plug so it wouldnt drain correctly and there it was wedged again the side.
PostPosted: Thu Nov 05, 2009 5:12 pm
Not fall out like that - but I had to dig out quite a lot from the clutch end rear side of the block - and between 3 and 4 - no wonder the PO had an overheating problem :roll:
Users browsing this forum: drmini in aust and 114 guests
