morris 1100 disc brake swap https://www.ausmini.com/forums/viewtopic.php?f=2&t=58620 |
Author: | bradley [ Mon Nov 09, 2009 1:35 pm ] |
Post subject: | morris 1100 disc brake swap |
hello can i put 1100 disc brakes of a morris 1100 on my clubyvan. |
Author: | drmini in aust [ Mon Nov 09, 2009 2:01 pm ] |
This Q comes up all the time. Short answer is NO... not really. |
Author: | bradley [ Mon Nov 09, 2009 4:32 pm ] |
is there any way to put them on. how come they dont fit or go on |
Author: | Morris 1100 [ Mon Nov 09, 2009 4:43 pm ] |
They are much taller between the ball joints. If you do manage to fit them between the wishbones it stuffs the geometry up that much that they are useless. |
Author: | bradley [ Mon Nov 09, 2009 4:56 pm ] |
thank you no worris got stung again got told they will fit straight on now what to do with them |
Author: | Morris 1100 [ Mon Nov 09, 2009 5:10 pm ] |
Send them back to the seller for a refund. |
Author: | ALPINE MOKE [ Mon Nov 09, 2009 7:57 pm ] |
Post subject: | 1100 discs |
You can convert them to fit with a bit of work, the calipers will only fit 12" or 13" wheels a lot of them were used on mokes, cheap conversion when the 8-4 discs were not available as they are now. is it wort the effort NO. Les |
Author: | bradley [ Tue Nov 10, 2009 6:12 pm ] |
i have a complete front cut of an 1100 my local mini mech said he could get it all sweet set up working for $250 on my little van so all up i can can have a disc brake set up brought and put on for $400 is it worth it or should i just fork out the $1000 for a real mini set cos i will have to get bigger wheels . |
Author: | 74snail [ Tue Nov 10, 2009 6:22 pm ] |
bradley wrote: i have a complete front cut of an 1100 my local mini mech
said he could get it all sweet set up working for $250 on my little van so all up i can can have a disc brake set up brought and put on for $400 is it worth it or should i just fork out the $1000 for a real mini set cos i will have to get bigger wheels . Are you serious ! If your keen on using the motor just mount it on a proper Mini front subframe and just use standard drums , use the money you would waste on 7.5 disks on getting the motor sorted. . |
Author: | drmini in aust [ Tue Nov 10, 2009 6:26 pm ] |
I would save your money and go buy some proper Mini ones. 7.5" for 10" wheels, or 8.4s for bigger ones. Yes I have seen 1100 brakes butchered to `work' on a Mini, but these days IMO it's a waste of time and $$$. If they bugger up your suspension geometry or fail when you need them, you will not be a happy chappy. ![]() |
Author: | bradley [ Tue Nov 10, 2009 6:45 pm ] |
no worris ill stick to the real mini disc save any hasell thanks guys |
