997 or something else? https://www.ausmini.com/forums/viewtopic.php?f=2&t=58635 |
Author: | dezynablue [ Mon Nov 09, 2009 9:36 pm ] |
Post subject: | 997 or something else? |
Im just trying to identify an engine i have sitting in my workshop, any advice i can get would be helpful. The block has very few markings except a 12a497 on the side with a stamped number 1015/5164 on the top face, The head has no markings were they should be except a ECAM4004 on one end and up near the waterpump end it has 4 C7 or a 4 G7 that i couldnt quite make out, this didnt match up with any book or online reference. I then measured the bore it was 62.45ish with the vernier and the stroke was 81.5 also with vernier so might be a few thou off, this matches up with a early 997cc cooper. is there any other marks or identification i can look for? Any help with this mystery would be most appreciated John |
Author: | sgc [ Mon Nov 09, 2009 9:55 pm ] |
Post subject: | Re: 997 or something else? |
dezynablue wrote: a stamped number 1015/5164 on the top face,
The head has no markings were they should be except a ECAM4004 I believe the 12a497 casting was common to all smallbores, 997 to 1098. Can anyone else confirm that? A 1015/ series engine number is a late Oz 1098, up until circa-1975. I think the CAM4004 was the smog head fitted to 998's? |
Author: | drmini in aust [ Tue Nov 10, 2009 6:52 pm ] |
Simon is correct... ^^^ ![]() It could have a 997 Cooper crank in it if that stroke is correct. They are pretty much a 1098 crank dimensionally with slightly less stroke. No stronger, or weaker. Just rarer.... Unless that smog head has been well worked over with big valves, it will go better with a 12G202 (1098) head or better still a 12G295 (cooper 998) one. |
Author: | Goldbrocade_62 [ Wed Nov 11, 2009 2:46 pm ] |
does motor have fuel pump |
Author: | dezynablue [ Wed Nov 11, 2009 10:44 pm ] |
Goldbrocade_62 wrote: does motor have fuel pump
Possibly, there are a lot of bits with it in boxes, ill have to see what one looks like and go hunt for it |
Author: | graham in aus [ Thu Nov 12, 2009 11:43 am ] |
Goldbrocade means does the block have a hole for a mechanical pump, or is the pump still bolted onto the back of the block? ![]() |
