OK, maybe it's not a 90's Stalk, maybe it's 80's. It does not have an intermittent wipers position, just low, high and then a springloaded position beyond high I assume is wash and wipe at the same time. Pushing the end of the stalk should run the washers only.
I have the ignition switch, horn and dip all working.
I'm left with five wires on the stalk. I've tried various combinations but have not found one that has all functions working. I'm not fussed about Park, as it does not work in the current motor anyway. I just want low, high and the washers working. I'm fitting this column because I'm sick of leaning forward to grope on the dash in the dark.
I was hoping someone could tell me connect X to Y and ignore Z as I doubt I'm the first person to attempt this. If I have to I will sit down with a test lamp and figure it out. So far I've just got things arse about - for example washers operating at the high speed position.
