It is currently Mon Aug 04, 2025 1:32 am
 Post subject: Suspension cone 'washer'
PostPosted: Thu Nov 12, 2009 10:15 pm
Hi all,
Am in the process of rebuilding my front end, which is a mix of Moke and Rover bits.
The Moke 'hilos' are stuffed, they are threaded into the really flattened cones and then well rusted there, no wonder I could never turn the adjusting nuts!
So I plan to use the rover trumpets new cones, and rover swing arms...
When I pulled the rover bits apart there is a 2.5 or 3mm thick washer between the trumpet and ball, which i figure gives about 5-10 mm height lift, so if I take the washer out, it will be lowered by 5-10 mm.
So what is the ratio between the swing arm pin, cone ball/socket and axle so I can calculate this height change?
And does the washer do anything else (other than hieght change)?
I know I should just buy some hi-lows, but not right now OK!
Cool stuff!!
PostPosted: Fri Nov 13, 2009 6:14 am
The ratio of the front arms is 3 : 1 and for the rears (in case you need it) is 5 : 1.
The washers are only used for height adjustment.
Trust this helps.
PostPosted: Fri Nov 13, 2009 6:35 am
cool thanks for your reply.
Cool stuff!!
