Suspension cone 'washer' https://www.ausmini.com/forums/viewtopic.php?f=2&t=58709 |
Author: | mollymoke [ Thu Nov 12, 2009 10:15 pm ] |
Post subject: | Suspension cone 'washer' |
Hi all, Am in the process of rebuilding my front end, which is a mix of Moke and Rover bits. The Moke 'hilos' are stuffed, they are threaded into the really flattened cones and then well rusted there, no wonder I could never turn the adjusting nuts! So I plan to use the rover trumpets new cones, and rover swing arms... When I pulled the rover bits apart there is a 2.5 or 3mm thick washer between the trumpet and ball, which i figure gives about 5-10 mm height lift, so if I take the washer out, it will be lowered by 5-10 mm. So what is the ratio between the swing arm pin, cone ball/socket and axle so I can calculate this height change? And does the washer do anything else (other than hieght change)? I know I should just buy some hi-lows, but not right now OK! |
Author: | GT mowog [ Fri Nov 13, 2009 6:14 am ] |
The ratio of the front arms is 3 : 1 and for the rears (in case you need it) is 5 : 1. The washers are only used for height adjustment. Trust this helps. |
Author: | mollymoke [ Fri Nov 13, 2009 6:35 am ] |
cool thanks for your reply. |
