It is currently Sat Aug 02, 2025 1:36 pm
PostPosted: Fri Nov 13, 2009 2:06 pm
Hello all, it's still gareth-in-Adelaide but decided to change my name to my cars new name!
Originally was calling it blue thunder but more in the mini spirit I have shortened it to Blunder! Lol
but anyway back to topic title! I have removed my under bumper spots as I was having the paint done and well basically they fell apart! So really wanting spits but also wanting to put back the clubman under riders so looking for above mounts!
So what have you done on you clubman and please do show! Would love and LS or a like of grill with the built ins if anyone has one going otherwise open to suggestions!
Thanks
PostPosted: Fri Nov 13, 2009 4:11 pm
The first photo is how I,ve set up my single Lucas 55W driving light on a Single Lucas light bracket this is wired to the high beam switch , I removed the dimmer switch for the binnacle and connected the wires and used the dimmer switch bracket to mount a switch for the the driving light, so high beams on / power to the light / pull the switch/ high beams driving light on/off with high beam switch . And yes that is Asparagus zip-tied to the aerial
[img][img]http://img200.imageshack.us/img200/6707/p1000451.jpg[/img][/img]
Second photo was the "Snail" at the MiniShow 50th , Lucas 55w driving lights mounted on Lucas light brackets with the bracket over-riders clipped on, this was not wired up , just for display only, I did'nt have the right bolts to mount them securely .
[img][img]http://img11.imageshack.us/img11/3586/p1000404h.jpg[/img][/img]
