It is currently Mon Aug 11, 2025 12:00 pm
PostPosted: Mon Nov 16, 2009 9:09 am
The seals in the quater windows were replaced but the don't seem to be in the bottom rail properly, is there and trick way to het them
in!?
Tried brute force and ignorance and it didn't work so any help/suggestions would be great!
PostPosted: Mon Nov 16, 2009 9:14 am
I used a smear of rubber grease (lanolin) and makes it goes in a lot easier.
Dave K.
PostPosted: Mon Nov 16, 2009 9:17 am
As dave says, you need to use rubber grease (same stuff used for putting brake cylinders together with) and lots of patence. Don't use 'normal' grease.
also try;-
http://www.ausmini.com/forums/viewtopic.php?t=10443
