Radiator Cap
https://www.ausmini.com/forums/viewtopic.php?f=2&t=58806
Author:  TK [ Mon Nov 16, 2009 1:11 pm ]
Post subject:  Radiator Cap
OK the search function returned nothing.
I'm putting a plastic recovery system on the Mini. The guy at Supercheap said my existing radiator cap will be fine. I know that is crap. So I went to REPCO and they gave me RC64-13 replaces CPC 508-13. When I googled the CPC 508-13 it says it has the short 22mm cap. I thought I would need a 27mm cap?
Ideas please, once and for all.
Author:  Tombo [ Mon Nov 16, 2009 1:20 pm ]
I just put on a new long cap CPC 517-13 by memory, they however are not a proper recovery cap.
Just looked in our tridon book, the recovery cap it claims fits a mini (72-83) is CA4313.
Hope that helps.
Author:  MiniDna [ Mon Nov 16, 2009 2:58 pm ]
Hi I just put recovery as well and I put 537-14 (I have aircon)
Author:  ryan [ Mon Nov 16, 2009 3:01 pm ]
Guys, This is all just theory from what I have read, but......
this is how I believe it works.
You, put a blanking cap on the radiator and then, you need a cap that its suitable for your overflow tank.
I bet I got that wrong! :lol:
Author:  sgc [ Mon Nov 16, 2009 3:24 pm ]
That's right if the overflow tank is pressurised.
If the overflow is not pressurised, you still need a pressure cap on the radiator, but one which allows the fluid back into the radiator as it cools and contracts.
Author:  ryan [ Mon Nov 16, 2009 4:22 pm ]
Thanks for clearing that up for me SGC, I didn't realise that there were non pressurised tanks available.
Author:  Morris 1100 [ Mon Nov 16, 2009 4:25 pm ]
Look under the bonnet of any car made in the last 20 years. :lol:
Author:  sgc [ Mon Nov 16, 2009 4:29 pm ]
Yep, it's one less pressurised vessel/hose to fail..
Author:  ryan [ Mon Nov 16, 2009 4:37 pm ]
Good point Morris ......Very good point.....My brain isn't in gear!
Author:  Minimad [ Mon Nov 16, 2009 6:26 pm ]
You can not buy a recovery type long neck cap...
Best thing to do is to pull the radiator out and take to your local rad shop and have them fit a short neck to it.
Mine needs to be done at the next engine out.
Minimad
Author:  TK [ Mon Nov 16, 2009 8:40 pm ]
Craig (Minimad) is correct.
Dad took the radiator to the local Natrad and they said the same. I now have a short neck put on the top tank with a Commodore cap so it can be used with a non presurised overflow tank. If I want to use a Morris 1100/Moke etc etc brass presurised tank I can just chuck on a flat cap. :)
Thanks for the replies
