It is currently Mon Aug 04, 2025 5:15 am
PostPosted: Tue Nov 17, 2009 9:35 am
hi all i am having a bit of a problem burning out the no 4 exaust valve this is the 3rd this year now i know there is other problems with the motor as in the rings are on there way out hence going through about 1 litre of oil every 100km i know it does need a rebuild but finances wont allow me the pleasure at the moment and i need to keep this car on the road for a little while longer at least
any ideas are greatfuly accepted
Peter.
A almost Bog Stock 1977 LS
1969 morris mini panel van, a work in progress
PostPosted: Tue Nov 17, 2009 10:25 am
My thoughts.
Burnt oil = carbon
carbon under valve = burnt out valve
perhaps #4 is the worst burning and hence creating the most carbon
If I am right the only way to "fix" it is to rebuild properly.
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Tue Nov 17, 2009 11:13 am
Fix valve, then decoke every few weeks using the water trick to prevent such a carbon buildup.
PostPosted: Tue Nov 17, 2009 12:25 pm
no problem the rebuild i think will be the only fix unfortuantly im going to have to patch it up till i get another car which hopfully will be in a fortnight till then i can just hope it will get me to work and back
peter.
PostPosted: Tue Nov 17, 2009 1:54 pm
What is the water trick? Is that spraying water into the carb throat with engine running?
Copper 4 lyfe!
PostPosted: Tue Nov 17, 2009 2:20 pm
yep, but in small amounts i.e. a spray bottle, not a garden hose.
PostPosted: Tue Nov 17, 2009 2:27 pm
NAV-MAN
Yeah but if he used the garden hose he would not have to worry about a burn't valve, just broken &/or bent everything else
PostPosted: Tue Nov 17, 2009 2:37 pm
I just did some googling and found this page which described a mechanic hooking up a hose to the vacuum port with the other end in a bottle of water :shock: Hmm I might try that actually, with a hose clamp to control the rate. That'll allow me to do this trick without an assistant ^_^
Copper 4 lyfe!
Users browsing this forum: Bing [Bot] and 87 guests
