burnt out valve again.... https://www.ausmini.com/forums/viewtopic.php?f=2&t=58830 |
Author: | I_AM_THE_WAHL [ Tue Nov 17, 2009 9:35 am ] |
Post subject: | burnt out valve again.... |
hi all i am having a bit of a problem burning out the no 4 exaust valve this is the 3rd this year now i know there is other problems with the motor as in the rings are on there way out hence going through about 1 litre of oil every 100km i know it does need a rebuild but finances wont allow me the pleasure at the moment and i need to keep this car on the road for a little while longer at least any ideas are greatfuly accepted Peter. |
Author: | Panthersteve [ Tue Nov 17, 2009 10:25 am ] |
My thoughts. Burnt oil = carbon carbon under valve = burnt out valve perhaps #4 is the worst burning and hence creating the most carbon If I am right the only way to "fix" it is to rebuild properly. Steve |
Author: | awdmoke [ Tue Nov 17, 2009 11:13 am ] |
Fix valve, then decoke every few weeks using the water trick to prevent such a carbon buildup. |
Author: | I_AM_THE_WAHL [ Tue Nov 17, 2009 12:25 pm ] |
no problem the rebuild i think will be the only fix unfortuantly im going to have to patch it up till i get another car which hopfully will be in a fortnight till then i can just hope it will get me to work and back peter. |
Author: | headgasket [ Tue Nov 17, 2009 1:54 pm ] |
What is the water trick? Is that spraying water into the carb throat with engine running? |
Author: | awdmoke [ Tue Nov 17, 2009 2:20 pm ] |
yep, but in small amounts i.e. a spray bottle, not a garden hose. |
Author: | NAV [ Tue Nov 17, 2009 2:27 pm ] |
awdmoke wrote: yep, but in small amounts i.e. a spray bottle, not a garden hose.
Yeah but if he used the garden hose he would not have to worry about a burn't valve, just broken &/or bent everything else |
Author: | headgasket [ Tue Nov 17, 2009 2:37 pm ] |
I just did some googling and found this page which described a mechanic hooking up a hose to the vacuum port with the other end in a bottle of water ![]() |
