A+ diff ratios
https://www.ausmini.com/forums/viewtopic.php?f=2&t=58845
Author:  kiwiinwgtn [ Tue Nov 17, 2009 6:25 pm ]
Post subject:  A+ diff ratios
Hi
Will an A+ crown and pinion fit a non a plus box (rod change)
Ta
Kiwiinwgtn
Author:  drmini in aust [ Tue Nov 17, 2009 6:31 pm ]
Yes.
The only problem you will have with the taller ratios is the bigger diameter pinion will foul inside the bearing retainer.
Simply put the retainer in a lathe and bore it out to clear.
Author:  850man [ Tue Nov 17, 2009 6:31 pm ]
Yes :D
Author:  kiwiinwgtn [ Tue Nov 17, 2009 6:38 pm ]
Hi Kev
Not sure what you mean by bearing retainer
Ta
Kiwiinwgtn
Author:  drmini in aust [ Tue Nov 17, 2009 6:41 pm ]
The big cast steel thing (3 or 4 bolts) that holds the mainshaft bearing in... it's behind/around the diff pinion.
It clears a 3.44 pinion, maybe a 3.2, any taller ratio and you'll have to bore it out slightly.
Author:  kiwiinwgtn [ Tue Nov 17, 2009 6:57 pm ]
Thanks
Now to find one
:cry:
