Converting 850 engine to unleaded https://www.ausmini.com/forums/viewtopic.php?f=2&t=58897 |
Page 1 of 2 |
Author: | tomar [ Thu Nov 19, 2009 7:03 pm ] |
Post subject: | Converting 850 engine to unleaded |
How ? I am a beginner ! |
Author: | Morris 1100 [ Thu Nov 19, 2009 7:06 pm ] |
Step 1: Fill the tank with unleaded. Step 2: Drive it. |
Author: | micowen [ Thu Nov 19, 2009 7:07 pm ] |
Morris 1100 wrote: Step 1: Fill the tank with unleaded.
Is it just as easy to convert it back to leaded? ![]() |
Author: | Morris 1100 [ Thu Nov 19, 2009 7:09 pm ] |
micowen wrote: Morris 1100 wrote: Step 1: Fill the tank with unleaded. Is it just as easy to convert it back to leaded? ![]() Unfortunately no. You have not been able to buy leaded petrol for over 10 years. |
Author: | jimmyinamini [ Thu Nov 19, 2009 7:17 pm ] |
Step 2: Drive it. dont forget the valve saver fluid ,or your car may explode at speeds above 25 |
Author: | drmini in aust [ Thu Nov 19, 2009 7:19 pm ] |
Step 2: Drive it. Yeah that'll work, for a while.. then: Step 3: Rebuild the head with unleaded seats once the valves have sunk into the head, or burned out. 850 exhaust valves were not made from the greatest material. ![]() |
Author: | headgasket [ Thu Nov 19, 2009 7:24 pm ] |
What are the symptoms of a leaded head experiencing valve seat recession? I have NFI what my engine is but I've been running it on unleaded... ![]() |
Author: | Morris 1100 [ Thu Nov 19, 2009 7:25 pm ] |
drmini in aust wrote: Morris 1100 wrote: Step 1: Fill the tank with unleaded. Step 2: Drive it. Yeah that'll work, for a while.. then: Step 3: Rebuild the head with unleaded seats once the valves have sunk into the head, or burned out. 850 exhaust valves were not made from the greatest material. ![]() It has worked for my Morris 1100 for the past 7 years. Drive it everyday too. |
Author: | Morris 1100 [ Thu Nov 19, 2009 7:28 pm ] |
headgasket wrote: What are the symptoms of a leaded head experiencing valve seat recession? I have NFI what my engine is but I've been running it on unleaded...
![]() The exhaust valve clearances close up, so the valves eventually don't shut all the way, soon followed by a burnt exhaust valve. So check your valve clearances regularly to see if the exhaust valves are closing up. |
Author: | jimmyinamini [ Thu Nov 19, 2009 7:30 pm ] |
[/quote] It has worked for my Morris 1100 for the past 7 years. Drive it everyday too.[/quote] do you use the valve saver fluid ![]() |
Author: | drmini in aust [ Thu Nov 19, 2009 7:30 pm ] |
Morris 1100 wrote: drmini in aust wrote: Morris 1100 wrote: Step 1: Fill the tank with unleaded. Step 2: Drive it. Yeah that'll work, for a while.. then: Step 3: Rebuild the head with unleaded seats once the valves have sunk into the head, or burned out. 850 exhaust valves were not made from the greatest material. ![]() It has worked for my Morris 1100 for the past 7 years. Drive it everyday too. Aha yes but the head hasn't been rebuilt in the last 10 years, has it!! I got valve seat recession in a 1098 head in 6 months from rebuild. All it took was use no additive and let my 18 year old son drive it as usual. Note I did this on purpose, to see with my own 2 peepers what happens. ![]() The hot valves pulled bits of iron out of the head... My 1360 gets Flashlube additive, it works for me. As it did for all those old iron-headed Holden taxis on LPG years ago. |
Author: | jimmyinamini [ Thu Nov 19, 2009 7:35 pm ] |
so tomar looks like you can just add the lube when filling or rebuild your head (your cylender head not your other head ) ![]() |
Author: | tomar [ Thu Nov 19, 2009 7:38 pm ] |
so you are saying I need my head looked at! |
Author: | Morris 1100 [ Thu Nov 19, 2009 7:44 pm ] |
tomar wrote: so you are saying I need my head looked at!
Get the head looked at (eventually) All you need to do is get hardened valve seats fitted. |
Author: | Phat Kat [ Thu Nov 19, 2009 7:49 pm ] |
Morris 1100 wrote: tomar wrote: so you are saying I need my head looked at! Get the head looked at (eventually) All you need to do is get hardened valve seats fitted. Yep... and stainless valves (or nimonic) |
