It is currently Sat Jul 26, 2025 4:59 pm
PostPosted: Fri Nov 20, 2009 10:02 am
Does anybody know the torque for the castled nut that secures the front hub?
Thanks
PostPosted: Fri Nov 20, 2009 10:08 am
torque is cheap
PostPosted: Fri Nov 20, 2009 10:17 am
This space for rent
Disc is 150 ft-lb from memory, drum is 60 ft-lb.
Tighten to the recommended torque, then keep going until the split pin hole lines up.
PostPosted: Fri Nov 20, 2009 10:32 am
Yes - 150 for Discs
PostPosted: Fri Nov 20, 2009 10:37 am
and recheck them after youve done a good 500-1000kms, they will free up a little and may need retightening.
PostPosted: Fri Nov 20, 2009 10:42 am
great thanks - 60lb/ft isnt much for the drum.
PostPosted: Fri Nov 20, 2009 10:57 am
60lb/ft is all the drum CVs can stand, as the thread is much smaller.
I have seen people pull the thread clean off! :shock:
So use 60lb/ft, even if you have converted them to Timken roller bearings.
If unsure what you have, the drum nut is 1-1/8" hex size, the disc nut is 1-5/16" or 34mm hex size.
PostPosted: Fri Nov 20, 2009 10:58 am
Depends on the CV, i bought two new ones this tour, and one is 1 1/8" and the other is 1 1/4" so i have two different nuts on the front hubs
PostPosted: Fri Nov 20, 2009 11:01 am
any clue on the split pin width - can be bothered checking all the 8,000,000 little boxes of split pins in the garage
PostPosted: Fri Nov 20, 2009 11:12 am
1/8" pin for a drum CV.
PostPosted: Fri Nov 20, 2009 11:28 am
great - thanks
PostPosted: Fri Nov 20, 2009 2:38 pm
If it was torqued up to 150ft-lb and then you keep going, how much would that increase the torque to - since you're tightening it MORE to line the holes up?
-Alan
PostPosted: Fri Nov 20, 2009 2:42 pm
This space for rent
Dunno, but that's how it's been done since time began. If your bearing preload is correct, it won't matter anyway.
My brother thought it was wrong once and backed off to the previous hole, then wondered why he kept breaking split pins and (very nearly) losing wheels.
PostPosted: Fri Nov 20, 2009 2:57 pm
Early disc CVs had 2 split pin holes. New ones only have 1.
The current specs say torque to 150, then tighten to the next hole. It will be below 190 and that is OK.
PostPosted: Fri Nov 20, 2009 3:02 pm
I find it amazing the difference in torque (ie strength of CV's & thread) between drums & discs!
-Alan
