headgasket wrote:
Does anyone have any stencils? Also, where can I buy the backing board and black vinyl from (inner west sydney).
Hi headgasket,
there is a motor trimming supply shop at Prospect,, very good selection of stuff there. You'll be able to get your backing board and vinyl there and its pretty cheap....
as far as a stencil goes, I normally use the old one that I pulled out and either re-cover it or trace it. If you do not have one at all, you can get some butchers paper and place it over the parcel shelf flat, and press it into the edges,, it will give you a line to cut on. I will not be an exact fit but its a good starting point and you can just cut little bits of here and there til it fits,,, once the paper pattern is good, trace it onto the backing board and there you go
