It is currently Wed Jul 23, 2025 9:50 pm
 Post subject: Exhaust wrap smoking
PostPosted: Thu Nov 19, 2009 8:04 pm
How hot is the exhaust manifold meant to get? After rebuilding the engine, I ran the cam in and kept it above 2000rpm, after awhile the extractors were glowing red!
The paint in the engine bay directly next to the exhaust was burning and smoking! So I bought some exhaust wrap to help insulate some of the heat. My question is, does exhaust wrap smoke when new:?:
Here is a video of it starting to smoke up
http://www.youtube.com/watch?v=PBEp98OALnM
And one after the engine is off
http://www.youtube.com/watch?v=SmdzG38NSaY
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Thu Nov 19, 2009 8:10 pm
I don't think the exhaust is supposed to get red, I'd see if your car is running too lean.
PostPosted: Thu Nov 19, 2009 8:12 pm
needs to be tuned... timing is way out.
been told same thing from some one once...
PostPosted: Thu Nov 19, 2009 8:13 pm
I swapped in a new needle today, old needle was infact running too lean mid-high end. Old needle was a BBA, new is BCF.
But is exhaust wrap meant to smoke up? :?
Seems an awful lot of smoke.
PostPosted: Thu Nov 19, 2009 8:15 pm
Exhaust wrap smokes till it is cured.
PostPosted: Thu Nov 19, 2009 8:17 pm
Cool, will let it smoke more and will also check my timing tomorrow.
Thanks guys!
PostPosted: Fri Nov 20, 2009 12:33 am
where can you buy exhaust wrap,tried up here,no go????
First you get the money,then you get the power,then you get the Mini.
PostPosted: Fri Nov 20, 2009 10:12 am
I got mine at Rice Barn years ago.
PostPosted: Fri Nov 20, 2009 10:15 am
This space for rent
They still have it, I saw it there a couple of weeks ago when buying extractor paint.
PostPosted: Fri Nov 20, 2009 10:28 am
be wary of the exhaust heating up the carby, this will affect the performance and tuning of the carby.
PostPosted: Fri Nov 20, 2009 10:33 am
I bought mine online from eBay, seemed like the cheapest option compared to retail stores.
PostPosted: Fri Nov 20, 2009 1:03 pm
try road and track in ipswich. or revolution racegear. i live ipswich way so road and track would be the easiest. not sure if they actually stock it anymore though. revolution racegear carry that stuff in stock. they have a branch here in brisbane somewhere.
Jason
Ipswich
PostPosted: Fri Nov 20, 2009 11:53 pm
thanks lads,have aquired some from rice barn,did find it has effected the carby tuning,ie mixture and idle settings,only thing i can think of is the inlet manifold is running cooler,will go for a blast tomorrow,cheers andy..
Users browsing this forum: Nbmini33 and 112 guests
