Brown muck on spark plugs do i go hotter or cooler????
https://www.ausmini.com/forums/viewtopic.php?f=2&t=59065
Author:  Gadgets mini [ Wed Nov 25, 2009 8:34 pm ]
Post subject:  Brown muck on spark plugs do i go hotter or cooler????
Pulled the plugs today NGK BP6ES and the electrodes were covered in a light brown muck they were only oily on the threads.
Question is do i need to go hotter or cooler or stay the same ???
its a 1098
Author:  drmini in aust [ Wed Nov 25, 2009 8:36 pm ]
Are you running Valvemaster additive?
It really craps plugs up bad with brown sh!te...
A light brown to grey deposit is fine. A BP6ES plug is OK in most motors.
Author:  Gadgets mini [ Wed Nov 25, 2009 8:37 pm ]
yes Doc when i remember to add it :oops:
Author:  drmini in aust [ Wed Nov 25, 2009 8:39 pm ]
I would seriously NOT run it. Use Flashlube, it's cheaper, and doesn't leave any crap there. 8)
Author:  Gadgets mini [ Wed Nov 25, 2009 8:43 pm ]
Doc,
I just checked the bottle and it is Flash lube not the other stuff and i generally run Mobil premium in it
will it leave that muck if it runs lean??
Author:  drmini in aust [ Wed Nov 25, 2009 8:45 pm ]
Nope it shouldn't. Did you run Valvemaster before? More likely to run white if it's lean. If so I'd bung 4 new plugs in...
Author:  Gadgets mini [ Wed Nov 25, 2009 8:47 pm ]
Nope it shouldn't. Did you run Valvemaster before? If so I'd bung 4 new plugs in...
No pretty sure i have always run flash lube in it have run an ethanol blend a couple of times before i read here that it is not a good idea if running SU's
Author:  sgc [ Wed Nov 25, 2009 9:19 pm ]
That's because the ethanol eats certain types of rubber, like the O-ring seal in the outlet from the float bowl.
Different brands of fuel will burn differently and leave different deposits.. personally I stay away from Shell and stick to BP Ultimate.
I have found that after lots of K's without cleaning, I get a little brown plaque on my plugs.. I am running Valvemaster additive though. Might give Flashlube a run and see if it clears up! Thanks for the tip, Doc :D
