It is currently Thu Jul 24, 2025 7:23 am
 Post subject: Booster help.
PostPosted: Wed Nov 25, 2009 8:54 pm
my booster has this odd one way valve on it.
do i need it on? or can i pipe straight onto the manifold.
i don't seem to be getting much suction with this valve on.
soo booster-----pipe-----<valve>---pipe------(manifold plug)
do i need a valve filter thing between the manifold & the booster?
do any of your cars have anything like this or is a pipe straight in ok?
thanks. :)
PostPosted: Wed Nov 25, 2009 8:59 pm
There MUST be a one way valve (check valve) in the line to the booster.
On most it is inside the elbow where the hose goes onto the booster.
PostPosted: Wed Nov 25, 2009 9:03 pm
that's what i thought the one way valvle would be at the bottom of the booster right? then a hose straight to the manifold?
so where that right angle plug fits into the booster would a one way valve right?
so it seems like it has 2 valves then?
PostPosted: Wed Nov 25, 2009 9:06 pm
The thing at the bottom is an air valve... :wink:
PostPosted: Wed Nov 25, 2009 9:15 pm
This space for rent
Yep. Imagine what would happen without it if the car backfired :!:
PostPosted: Wed Nov 25, 2009 9:16 pm
would i fly like peter pan? :twisted:
PostPosted: Wed Nov 25, 2009 9:27 pm
Tomboss Breweros
Damn skippy, your brakes would all be undone :shock:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Nov 25, 2009 9:38 pm
i have bleed up the system & the pedal seems to brake but i'm still having to push it pretty hard & it's only doing soft braking takes a while to brake.
would that mean air in the lines still?
i will get a pro to check it all out but would be nice to sort it out my self. ;)
PostPosted: Thu Nov 26, 2009 6:24 am
Hi NG. is the one way valve an in-line type? You might have it in back-to-front.
PostPosted: Thu Nov 26, 2009 8:42 am
what way are the arrows meant to face on that one way valve.
it has little arrows.
PostPosted: Thu Nov 26, 2009 9:24 am
towards the booster ?? i think
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Thu Nov 26, 2009 9:30 am
cool.
i had it the other way at first rock hard pedal..
flipped it around with arrows pointing towards manifold made the pedal better easier to push in.
PostPosted: Thu Nov 26, 2009 9:39 am
ok towards the manifold then :P haha
that sounds about right then if it made it easier
