Booster help.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=59069
Author:  NG [ Wed Nov 25, 2009 8:54 pm ]
Post subject:  Booster help.
my booster has this odd one way valve on it.
do i need it on? or can i pipe straight onto the manifold.
i don't seem to be getting much suction with this valve on.
soo booster-----pipe-----<valve>---pipe------(manifold plug)
do i need a valve filter thing between the manifold & the booster?
do any of your cars have anything like this or is a pipe straight in ok?
thanks. :)
Author:  drmini in aust [ Wed Nov 25, 2009 8:59 pm ]
There MUST be a one way valve (check valve) in the line to the booster.
On most it is inside the elbow where the hose goes onto the booster.
Author:  NG [ Wed Nov 25, 2009 9:03 pm ]
that's what i thought the one way valvle would be at the bottom of the booster right? then a hose straight to the manifold?
so where that right angle plug fits into the booster would a one way valve right?
so it seems like it has 2 valves then?
Author:  drmini in aust [ Wed Nov 25, 2009 9:06 pm ]
The thing at the bottom is an air valve... :wink:
Author:  sgc [ Wed Nov 25, 2009 9:15 pm ]
Yep. Imagine what would happen without it if the car backfired :!:
Author:  NG [ Wed Nov 25, 2009 9:16 pm ]
would i fly like peter pan? :twisted:
Author:  Tombo [ Wed Nov 25, 2009 9:27 pm ]
Damn skippy, your brakes would all be undone :shock:
Author:  NG [ Wed Nov 25, 2009 9:38 pm ]
i have bleed up the system & the pedal seems to brake but i'm still having to push it pretty hard & it's only doing soft braking takes a while to brake.
would that mean air in the lines still?
i will get a pro to check it all out but would be nice to sort it out my self. ;)
Author:  GT mowog [ Thu Nov 26, 2009 6:24 am ]
Hi NG. is the one way valve an in-line type? You might have it in back-to-front.
Author:  NG [ Thu Nov 26, 2009 8:42 am ]
what way are the arrows meant to face on that one way valve.
it has little arrows.
Author:  MiniMan_Alis [ Thu Nov 26, 2009 9:24 am ]
towards the booster ?? i think
Author:  NG [ Thu Nov 26, 2009 9:30 am ]
cool.
i had it the other way at first rock hard pedal..
flipped it around with arrows pointing towards manifold made the pedal better easier to push in.
Author:  MiniMan_Alis [ Thu Nov 26, 2009 9:39 am ]
ok towards the manifold then :P haha
that sounds about right then if it made it easier
