pics of cut up 2a629 head https://www.ausmini.com/forums/viewtopic.php?f=2&t=59112 |
Author: | david rosenthal [ Fri Nov 27, 2009 11:07 am ] |
Post subject: | pics of cut up 2a629 head |
some are bit hard to see but gives a idea of what it looks like inside. this shows the cut positions ![]() ![]() vertical cut thru No. 4 exhaust port ![]() horizontal cut thru No.4 exhaust port. shows the end of water jacket. ![]() vertical cut thru No's 3&4 inlet valves ![]() vertical cut between No's 2&3 exhaust valves. the center of the head ![]() close up of the water jacket between the two center exhaust v/vs..this is the area to be careful off if you undercut around the v/v seats. its not very thick here. ![]() vertical cut thru middle of No's 1&2 inlet v/v's ![]() horizontal cut thru N0 1 exhaust and No1&2 inlet port. the problem areas are the tapering of the inlet ports and side clearance to the push rod holes. The shoulder curves in the ports to the v/vs is not too bad, but do not cut too much off the curve as the wall will end up too thin. I use these head thickness as a guide to do a 202 as well. the thickness in the problem areas is roughly the same. |
Author: | MG Rocket [ Fri Nov 27, 2009 1:38 pm ] |
Thanks for the photos, David. Had you done any work on this head before cutting it up? |
Author: | 850man [ Fri Nov 27, 2009 3:13 pm ] |
Very nice. I did this to a badly cracked AEG163 head years ago at NMP with a powered hack saw. Its proberly still there. What did you use to cut the head up? Vizard has lots of photos in his book too. ![]() |
Author: | drmini in aust [ Fri Nov 27, 2009 3:33 pm ] |
These days a nice big metal cutting bandsaw is the go. ![]() |
