brake change -- 2 problems https://www.ausmini.com/forums/viewtopic.php?f=2&t=59121 |
Author: | estapol [ Fri Nov 27, 2009 6:03 pm ] |
Post subject: | brake change -- 2 problems |
hey guys just put new disc assemblies on my clubby just wondering why my wheels are so far out alignment???? like theres probably a 5 % difference in the alignment of the discs????? also i have dot 3 fluid in the reservoirs at the moment and ive got to bleed this to put the dot 4 in whats the best way to completely bleed the system?????? Cheers heaps Hoba |
Author: | DTrain [ Fri Nov 27, 2009 6:45 pm ] |
dont mix dot ratings = bad disc do change your alignment quite significantly, seach for the post about setting your alignment by yourself. it will get you close enough in order to drive to your alignment place |
Author: | encho [ Fri Nov 27, 2009 7:59 pm ] |
arent some brake fluids rated dot 3 and 4 try using one of those to bleed your brakes ,just bleed them till you get new fluid coming through ,than if you like bleed again. |
Author: | mini_mad_matt [ Fri Nov 27, 2009 11:24 pm ] |
Mixing brake fluids is ok, PROVIDED your not mixing with silicone fluid. And the easiest way to change the fluid, i think, is to suck out whats in the resevoir, fill it up with new, and then open the bleeders at each wheel and just keep the resevoir topped up. If the old fluid is a different colour, you can stop when you see clean fluid, or when you think its had enough. To avoid making a mess, clear small pipe, such as used in windscreen washers work well when slid over the bleeder. As for the alignment, could you elaborate? When you say alignment, what do you mean? Did you go from drums to disc, or just new discs? |
Author: | estapol [ Sat Nov 28, 2009 12:57 pm ] |
update: got everything back together ok just cant get the dam locking nut on the tie rods undone ahhhhh i just doused them in brake fluid and wd 40 to try and loosen em up see what happens in few hours. Just going to get a couple of bottles of dot 4 fluid and try and flush out the dot 3..... the only dot 3 thats left is the stuff in the return lines so with a full flush most of it should go away. any other suggestions are welcome Cheers Hoba |
