It is currently Sat Aug 16, 2025 12:46 pm
 Post subject: Generator to Alternator.
PostPosted: Sun Nov 29, 2009 3:25 pm
I am converting from a generator setup to a Lucas 15 AC alternator. I think from looking through previous posts the Lucas 15AC i have has an internal regulator as it has no plastic back on it and no wire connection for the F terminal on the alternator. Is this correct?
I am following Tony's link to rewiring for the alternator but would it also work if I:
Run one big heavy wire from + on back of Alternator to battery side of starter solenoid. The big wire that did run from back of generator to D on control box can be taped up both ends as no longer needed. The existing wire on battery side of starter solenoid that went to A on control box will now carry power to all the wires from AL, A, and D that are joined together.
E is disconected.
The small wire on D connects to F that goes to IND on alternator for charge light on dash.
I am thinking it will work but can someone please confirm.
Thanks.
 Post subject: Wiring mod
PostPosted: Sun Nov 29, 2009 6:13 pm
Adding a heavy wire for the charge lead is a good idea. It will also be a good idea if you use the rest of the original wires at THE OLD CONTROL BOX D+ to Alt B+ and all the A wires joind up to D+. As I explained in the How to. This will give you better voltage all round. Why leave wires that can help the system "Unused"?
"Let us remove your "SHORTS"
Users browsing this forum: No registered users and 321 guests
