Generator to Alternator. https://www.ausmini.com/forums/viewtopic.php?f=2&t=59179 |
Author: | mini0998 [ Sun Nov 29, 2009 3:25 pm ] |
Post subject: | Generator to Alternator. |
I am converting from a generator setup to a Lucas 15 AC alternator. I think from looking through previous posts the Lucas 15AC i have has an internal regulator as it has no plastic back on it and no wire connection for the F terminal on the alternator. Is this correct? I am following Tony's link to rewiring for the alternator but would it also work if I: Run one big heavy wire from + on back of Alternator to battery side of starter solenoid. The big wire that did run from back of generator to D on control box can be taped up both ends as no longer needed. The existing wire on battery side of starter solenoid that went to A on control box will now carry power to all the wires from AL, A, and D that are joined together. E is disconected. The small wire on D connects to F that goes to IND on alternator for charge light on dash. I am thinking it will work but can someone please confirm. Thanks. |
Author: | Convertible Mini [ Sun Nov 29, 2009 6:13 pm ] |
Post subject: | Wiring mod |
Adding a heavy wire for the charge lead is a good idea. It will also be a good idea if you use the rest of the original wires at THE OLD CONTROL BOX D+ to Alt B+ and all the A wires joind up to D+. As I explained in the How to. This will give you better voltage all round. Why leave wires that can help the system "Unused"? |
