Top arm shock absorber pin https://www.ausmini.com/forums/viewtopic.php?f=2&t=59188 |
Author: | Wombat [ Sun Nov 29, 2009 6:41 pm ] |
Post subject: | Top arm shock absorber pin |
Looks like a high tensile bolt - will one do as a substitute with a stack of washers as a spacer? |
Author: | GT mowog [ Sun Nov 29, 2009 7:04 pm ] |
The standard ones are only a grade 5 bolt - not teribly 'tensile'. These are OK for normal to moderate road use. Anything more you might want to go to a better grade bolt. There is a spacer, about 16 mm (5/8") long between the top arm and the shocker just to stop the body of the shock absorber banging in to the arm. Enough washers would also work OK. |
