It is currently Wed Jul 16, 2025 3:46 am
 Post subject: oil leak
PostPosted: Wed Mar 30, 2005 6:33 am
I have an oil leak which is coming from the 2 bolts
at R/H side rear of engine.
I think its the bolts for the gear detent plungers.
If they are the bolts that hold the detent plungers
can I remove them and change the seals and are
these seals copper or fibre washers.
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Wed Mar 30, 2005 6:51 am
Yes you can undo them and replace the copper washers. Note there's a spring under each plug.
You won't lose any oil if you're quick about it. :wink:
PostPosted: Wed Mar 30, 2005 7:10 am
Thanks doc.I'll get some washers and change them
when I do my oil change.
Felix
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
