oil leak https://www.ausmini.com/forums/viewtopic.php?f=2&t=5924 |
Author: | mini_me [ Wed Mar 30, 2005 6:33 am ] |
Post subject: | oil leak |
I have an oil leak which is coming from the 2 bolts at R/H side rear of engine. I think its the bolts for the gear detent plungers. If they are the bolts that hold the detent plungers can I remove them and change the seals and are these seals copper or fibre washers. |
Author: | drmini in aust [ Wed Mar 30, 2005 6:51 am ] |
Yes you can undo them and replace the copper washers. Note there's a spring under each plug. You won't lose any oil if you're quick about it. ![]() |
Author: | mini_me [ Wed Mar 30, 2005 7:10 am ] |
Thanks doc.I'll get some washers and change them when I do my oil change. Felix |
