KAD Rear disc brakes.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=59253
Page 1 of 3
Author:  bamnfi [ Wed Dec 02, 2009 5:55 pm ]
Post subject:  KAD Rear disc brakes.
Random, but at least the topic heading there!
Has anyone used them? What do folks think of lightening the sprung weight in the rear?
I gear a number of racers use them but are they any good for a reasonably fast road car?
Thanks in advance.
bam
Author:  awdmoke [ Wed Dec 02, 2009 5:59 pm ]
I dont have them, but they do work & lightening the unsprung mass is always a good thing. Braking will be unchanged - even drums can lock up the rear easily. They don't like repeated use for handbrake turns, so no suitable for khana cars.
In a road car, there are a lot more areas to remove weight from first.
Author:  bamnfi [ Wed Dec 02, 2009 6:08 pm ]
Well I figure removing weight from my wallet counts!
I also reckon the rust and muck cut out to be replaced by genuine metal must count.
Other than tha, for a road car, what can ya do :roll:
Author:  mini maxx [ Wed Dec 02, 2009 6:11 pm ]
If you like removing weight from your wallet, start with a f/glass bootlid or carbon fibre, theyl lighten the car and your wallet will float 3 ft off the ground :lol:
Author:  GT mowog [ Wed Dec 02, 2009 6:16 pm ]
I'd actually suggest look first at where the majority of the weight is - at the front - first, then start look elsewhere.
Author:  feralsprint [ Wed Dec 02, 2009 8:02 pm ]
you could always put alloy trailing arms and alloy minifin type drums on and save heap more weight if you like lightening your wallet
Author:  Smarty [ Wed Dec 02, 2009 8:25 pm ]
A bit off topic, but I have always wondered how to set up a hydraulic handbrake for the rear end, and if it interferes with the ordinary braking function?
Author:  1071 [ Wed Dec 02, 2009 8:26 pm ]
Or fit the KAD alloy rear arms ...and then fit the KAD alloy hubs, discs, etct etc..along with a carbon fibre boot lid, boot floor, era bumper (or just do away without one entirely). Just how light do you want your wallet to be :)
Cheers, Ian
Author:  mini maxx [ Wed Dec 02, 2009 8:28 pm ]
If you really want to lighten your wallet give all your spare cash to ME :lol: :lol:
Author:  Smarty [ Wed Dec 02, 2009 8:28 pm ]
http://www.force-racing.co.uk/rear-suspension/
8)
Author:  GT mowog [ Wed Dec 02, 2009 8:31 pm ]
It can be done 'seamlessly'. Standard Hydralic Foot Brakes will work normal and the cable hand brake (if you still retain it) will also work normal.
Author:  blue_deluxe [ Wed Dec 02, 2009 8:35 pm ]
Try searching for hydraulic handbrakes in the search.
Its basically another master cylinder that is plumbed into the rear brake lines. This master is then activated by a lever that can lock the rear brakes hydraulically.
Author:  bamnfi [ Wed Dec 02, 2009 8:39 pm ]
Smarty wrote:
Smarty, fully sick :roll:
Author:  blue_deluxe [ Wed Dec 02, 2009 8:44 pm ]
bamnfi wrote:
Now that is wank factor. With the price tag to match.
Id be going for them if i could afford it.
Author:  miniobsessed [ Wed Dec 02, 2009 9:04 pm ]
I have a set on my Mini.
They are much lighter than the drums and are still more than capable of locking up the rears. A nice bit of engineering too :)
But as awdmoke said they are not designed for handbrake turns or heavy rear brake bias or left foot braking...
Page 1 of 3 All times are UTC + 10 hours
