It is currently Sat Jul 19, 2025 9:30 pm
 Post subject: brake switch location
PostPosted: Sat Dec 05, 2009 11:18 am
hi guys,
a quick question:
where is the brake switch on a '65 mini deluxe?? i cant find it.
PostPosted: Sat Dec 05, 2009 11:21 am
If you follow the brake lines out of the master cylinder down to the drivers side of the subframe, they go into a small, about 40mm high from memory, and it should have connections on it.
This the brake light switch.
Simplify and add lightness
PostPosted: Sat Dec 05, 2009 11:22 am
Tomboss Breweros
In the engine bay, down low on the subframe on the rh side, its a 2 pin pressure switch.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Dec 05, 2009 7:45 pm
And if you buy a new one, don't expect it to last like the old one did. They are rubbish these days. :x
