It is currently Mon Jul 21, 2025 9:42 pm
 Post subject: HIF6/HIF44 Carb
PostPosted: Wed Mar 30, 2005 11:27 am
Are these carbs one and the same?
I see them listed together all over the place, can anyone shed any light?
Thanks!
PostPosted: Wed Mar 30, 2005 11:50 am
I believe so one is a measurement in imperial the other is metric, it explains it in TBLAE i think
100% Pure A Series Turbo
PostPosted: Wed Mar 30, 2005 12:38 pm
HS6 (if that is what you're talking about) is the 1.75" SU with the float on the side like a normal Mini SU (but bigger).
HIF44 is 1.75" with the float on the bottom.
Both the same size and both use the same needles and stuff.
PostPosted: Wed Mar 30, 2005 5:01 pm
HIF6 and HIF44 are the same just in metric and imperial measurements, they do use different needles and springs internally too, the piston is even on a ball bearing to assist in a smoth slide etc.
PostPosted: Wed Mar 30, 2005 5:06 pm
So is one better than the other? Also, 44mm ~= 1.75", what the hell is 6 for?
Can anyone tell me what he HIF bit stands for?
PostPosted: Wed Mar 30, 2005 6:00 pm
HIF = Horizontal Integrated Float Chamber
Was developed primarily to meet the requirements of exhaust emission control systems.
No me not that clever - i just bought the book last week LOL
PostPosted: Thu Mar 31, 2005 8:58 am
I think the 6 is for 6/8 ths the old imperial carbies were named with the number of 1/8 ths they were over an inch
so
HS2 = 1 1/4 inch carbie
HS4 = 1 1/2 inch carbie
HS6 = 1 3/4 inch carbe
Correct me if I am wrong :?
Roads need more corners
PostPosted: Thu Mar 31, 2005 1:18 pm
thas the one i think
Users browsing this forum: Phil 850, watsupskip and 93 guests
