It is currently Mon Jul 21, 2025 11:50 am
PostPosted: Sat Nov 28, 2009 4:12 pm
Seen these on e-bay, wondering if anyone has one and are they any good? They look too much of a bargin?
http://cgi.ebay.com.au/ALUMINUM-RADIATO ... 518c4276e6
Also seen silicon hoses, also look too much of a bargin!
http://cgi.ebay.com.au/AUSTIN-MINI-ROVE ... 2a00a1186f
PostPosted: Sat Nov 28, 2009 5:06 pm
yep, they`re ok, i`ve been using them for years
I`d put a sock in the top hose for a few weeks tho, just to try & catch any muck, helps to keep the thin cores clean,,, after a few weeks if you check the sock & it`s pretty clean then leave it out
easy-peasy
PostPosted: Sat Nov 28, 2009 9:20 pm
where can you get those socks these days? i remember seeing them at supercrap before it was called that (rocca bros in adelaide..., i believe it was something else in wa?)
anyways, radiator socks... where from?
cheers.
PostPosted: Sun Nov 29, 2009 10:47 am
My local Autopro has them
4efte powered Clubman
supercharged 998 race car
PostPosted: Sun Nov 29, 2009 12:16 pm
My wife's stocking drawer is another great source...
PostPosted: Sun Nov 29, 2009 12:59 pm
Fish nets Stockings don't Count unless they are yours Mike :roll:
PostPosted: Sun Nov 29, 2009 2:09 pm
http://ausmini.com/forums/viewtopic.php?t=55728&
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Sun Nov 29, 2009 4:22 pm
First time out in my car after the resto this week and using a Chinese aluminium radiator. Sitting in heavy traffic early last week and on a hot 32-34C day it worked admirably. Checked with infrared thermometer. Cylinder head ranged from 76 to 81C front to back. Header tank 60C.
Very happy so far. Bought mine from KoolNuts but dont see them advertising on Ebay at the moment.
PostPosted: Sun Nov 29, 2009 8:55 pm
I purchased a couple of these found they are ok, workmanship is not the greatest but the biggest issue I had was that they pack them very badly and when they arrived had dents and plenty of bent fins. I guess you get what you pay for.
PostPosted: Tue Dec 01, 2009 8:05 pm
I got one of these rads and yet to fit it, but it appears that the radiator that came out of this car is "wider" than the alloy one I purchased, hence the radiator shrouds are to wide ?, Any ideas please ?
I guess the question is ?, Do mini's have different width rad shrouds ?
Thanks
1964 Grp Nb Cooper S
1976 911 3.6 Circuit Car
1969 911T Grp Sb Historic Racer
2009 LC200 V8 TDI.... 660nm..
2011 Golf VI, TSI
PostPosted: Tue Dec 01, 2009 10:16 pm
Thanks
no,,, they`re the same(ish) depending on what country & year
But the issue i expect you`re having is that the corners of the alloy rad are quite square shaped,,, yet the old mini rads corners are quite rounded,,, so usually i tiny bit of trimming with snips is needed to get the rad to tuck (fully) into the shroud properly,,, so that the screw/bolt holse line up yeah?
no biggy tho,,, easy-peasy
PostPosted: Sat Dec 12, 2009 9:13 pm
have placed my order.... dang i hope mine comes in 1 piece...no 2 its got a cap, i think :lol: , will post what its like got mine from koolnuts & got some silicone pipes too as old ones could be used as a soaker hose :lol:
PostPosted: Sun Dec 13, 2009 2:06 pm
I bought one a while back, it looks alright and it was cheap.
I also got a Honda Civic one for my Starlet Mini project from a different supplier, but it appears to be very much the same.
Just make sure you use the correct cap.
PostPosted: Sun Dec 13, 2009 5:27 pm
Minis plus are also selling alloy rads (i think he said 4 core, could be 3) not sure on the price or effectiveness (he has sold a few and had no bad reports) as yet but quite happy to report when and if I put my car back together.
PostPosted: Sun Dec 13, 2009 5:31 pm
I saw these the other week, they are much thicker than the ebay rads and locally made.
