3 clock speedos
https://www.ausmini.com/forums/viewtopic.php?f=2&t=5946
Page 1 of 3
Author:  benjamin [ Wed Mar 30, 2005 8:09 pm ]
Post subject:  3 clock speedos
i have a Leyland mini EPAI 998 although has an 1100 now but i was wondering what models had the 3 clock speedo as standard as mine has a 3 clock speedo with the tacho wire built in the original wiring harness did mine come with the 3 clock speedo or do all models have that extra wire?
Author:  czerial [ Wed Mar 30, 2005 10:21 pm ]
common guys this is easy, can no one answer this question purely because its about a clubman?????????
benny, the three guage dash came out in
mini clubman s
mini clubman LS
mini clubman SS
mini clubman 1275LS
mini clubman Sunshine
hope that helps! but alot of people put three guage dashes in their clubbys so dont try to identify your car by the speedos, and they would not of had the wire from factory on the 2 guage if they didnt have the tacko with it :wink:
Author:  J_A_M [ Wed Mar 30, 2005 10:33 pm ]
i beg to differ....many cars came out with a standard loom, and wires that weren't used were just left there.
Saves the makers money to mass produce one type of loom. Maybe BMC/Leyland were different and didnt do this. :?
Author:  czerial [ Wed Mar 30, 2005 10:37 pm ]
ummm the wiring harness as far as i nkow is connected by that big pplug, if you were going to put the three guage in then youd need to put that blue plastic wire thing on and have the wire that connects teh speedo to the tacho.....i dont think the loom would have much to do with the tacho, it would come down to the plastic thing??? wouldnt it...
Author:  J_A_M [ Wed Mar 30, 2005 10:41 pm ]
no i dont think the tacho runs through the main plug. there are a few auxilary wires that plug straight into the tacho. maybe, could be......
Author:  czerial [ Wed Mar 30, 2005 10:44 pm ]
could be....i know there aint any extra wires in Vivian when i took her two guages out and there ain alot of extra space on the back of the 3 guage out of Elmo, BUT you have put JAMS back in so i think you would have the better answer to the wiring qstn to me, i have not given it a good look at :wink: just run out now and check anton :lol: :lol: :lol:
Author:  J_A_M [ Wed Mar 30, 2005 10:46 pm ]
hehehe....JAM's clocks and loom are in....but they aint connected yet! :lol:
Hey I got a new clubby interior light yesterday...mmm mmm...looks tops!
Author:  drmini in aust [ Wed Mar 30, 2005 10:46 pm ]
Early Clubbies with the tacho had the coil wiring circuit plugged into 2 banana plugs in back of tacho. The coil current went thru the tacho. Later ones, I have NFI. :lol:
Author:  czerial [ Wed Mar 30, 2005 10:46 pm ]
lucky bugger, i need two of them (one lizzie one elmo......if i ever finish them :lol: :lol:
Author:  1310/71 [ Wed Mar 30, 2005 10:48 pm ]
The wiring harness off any clubman will have the extra wires (2) for the tacho pretty much as Anton said in a previous post. I think it just draws power for the illumination from the plug, the two white(? - one may have a trace colour, blue?, I can't remember) are the ones to connect. They are a male and female connector so it is fairly obvious where they go when you look at the back of the tacho.
As chris said, many have been changed over the years so what it has in it now, is not necessarily indicative of what it came out with.
Author:  J_A_M [ Wed Mar 30, 2005 10:51 pm ]
ooohhhhhh...KB is running for the title of Doc Junior with that reply....nice one mate! 8)
Author:  drmini in aust [ Wed Mar 30, 2005 10:52 pm ]
Um... I put a 3 clocker into an early poverty model Clubbie once, and had to run these tacho signal wires! Were not in the loom.. :cry:
Author:  1310/71 [ Wed Mar 30, 2005 10:55 pm ]
I've been taking extra classes :D - had a tutorial tonight, plus a run round the district in Mini ha ha - all that torque and wet roads to boot. Even with a measured right foot on the Doc, it gets up & boogies!
:P
Author:  czerial [ Wed Mar 30, 2005 10:56 pm ]
thats the same as viv, no extra wires....
Author:  1310/71 [ Wed Mar 30, 2005 10:58 pm ]
My '71 clubman had them - someone could have changed the harness of course. All I did was unplug the two white wires that were joined together and plug them onto the respective lugs on the tacho. Easy peezy.
Page 1 of 3 All times are UTC + 10 hours
