4 sync gearboxes.... What are the different part Numbers????
https://www.ausmini.com/forums/viewtopic.php?f=2&t=59523
Page 1 of 2
Author:  wobbles_55 [ Sat Dec 12, 2009 7:02 pm ]
Post subject:  4 sync gearboxes.... What are the different part Numbers????
4 sync gearboxes with remote shift.... What are the different part Numbers????
Also what are the different types and so on.......
Any help would be geat............
Author:  drmini in aust [ Sat Dec 12, 2009 7:13 pm ]
Most are a 22G1128 casting.
There is another less common, 22G846.
Remote shift cases were used on:
Mini K
Mk2 Cooper S
1098 Clubby
Clubman GT
Mokes, pov pack Mini K & van (but with a puddin' stirrer adaptor)
Only the Mk2 Cooper S & Clubman GT got the closer S ratios.
Author:  GT mowog [ Sat Dec 12, 2009 7:16 pm ]
As far as the cases went, there was only 1, fitted to the Mini K, Cooper S and Early Clubman.
Internals were also a similar story, being standard ratios and cooper S.
Diff ratios were 3.7 for the Mini and 3.44 for the cooper S, which also had different output shafts from the diff and different covers over the output shafts.
I think the casing had a casting no of 12G 1128 or 22G 1128...
Author:  wobbles_55 [ Sat Dec 12, 2009 7:24 pm ]
Thanks for the help, I am just sorting through all of my mini bits at home and found a gearbox case with the numbers 22A599 any idea what that number relates to???? Or any tips on the difference between 4 sync and 3 sync boxes????
Author:  sgc [ Sat Dec 12, 2009 7:28 pm ]
Here's a 22A599:
http://cgi.ebay.co.uk/NOS-Transmission- ... 4cec74813f
Author:  drmini in aust [ Sat Dec 12, 2009 7:35 pm ]
Post subject:  Re: 4 sync gearboxes.... What are the different part Numbers
Look above and in front of the drain plug boss- 3 synchro ones are flat there, a 4 synchro is curved.
Author:  wobbles_55 [ Sun Jan 10, 2010 12:44 pm ]
Post subject:  4 sync boxes
Thanks for your help... What is a 22G1288 box?????
Author:  drmini in aust [ Sun Jan 10, 2010 12:47 pm ]
You will probably find it's a 22A1288. 3 synchro, 850/998 box.
22G1288 don't exist, in my books.
GT m, the Mini K and 1098 Clubby (same 4 synchro box) ran a 3.647:1 diff, not 3.7. :wink:
Author:  wobbles_55 [ Sun Jan 10, 2010 12:54 pm ]
Post subject:  4 sync.
The box has a virgin 1275 block attached to it....
Author:  drmini in aust [ Sun Jan 10, 2010 1:08 pm ]
Could be 22A1228 then.
3 synchro, used on Morris 1100S etc.
Author:  Boostedmini [ Sun Jan 10, 2010 8:55 pm ]
Ok i have a spare case that i hope is a 4 syncro box but the numbers do not mean anything to me, its a 22G68.
anyone know what that one is?
Author:  drmini in aust [ Sun Jan 10, 2010 9:32 pm ]
Sorry to burst your bubble Grant but a 22G68 is just 3 synchro- 850-997-998Cooper, remote or magic wand.
Author:  Boostedmini [ Mon Jan 11, 2010 6:07 am ]
Thanks Doc,
was worried you would say that :?
is it the same case as a MK1 "S" as i have one i need to rebuild (looking for a laygear assembly) and the case has been welded at the drain plug and i could swap it all over.
Grant
Author:  drmini in aust [ Mon Jan 11, 2010 6:35 pm ]
I think you will find it's maybe too narrow across the top to swing a 1275 crank and rods.
Put a tape on it... and compare it with the S one.
You could grind it out there if needed. All the Mk1 S gears will fit in.
I put a 1275 on an early 850 case once. Major surgery was needed- don't go there. :evil:
Author:  850 GT [ Sun Oct 03, 2010 9:54 pm ]
[quote="drmini in aust"]Most are a 22G1128 casting.
I picked up a 22G846 today, looks good inside.
Are all these boxes 4 syncro, and is the diff ratio 3.64:1
