It is currently Sun Aug 03, 2025 6:25 am
PostPosted: Wed Dec 16, 2009 11:08 am
Hi,
Can anyone point me to a clutch adjustment how to?
I can select all gears with the motor off, but with it running, the clutch is slightly engaged and I can't get from N to 1,2,3,4 or R.
Any help?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Wed Dec 16, 2009 11:47 am
Tomboss Breweros
Make sure it's bled properly.
Grab the release arm and pull it toward the guard, there should be about a 20 thou (.5mm) gap between it and the small adjuster bolt on the housing :wink:
kimini wrote:
Jimmyinamini wrote:
