Well guys, sorry bout the late replies i was on holiday.
anyway..
It will really help us to know what type of gearbox you have.
i've only just got back so i'll have a look as soon as i can and let you know
does it make any unusual noises since.
nope no strange noises since at all, and as for the oil change i will get onto that for sure.
An indication the box is worn and begs for an overhaul. Areas of concern most likely are 1st motion shaft spiggott bearing, selector forks, syncro rings and undoubtedly the layshaft and bearings.
Nothing that can't be tackled without the help of the friendly staff of Ausmini
ok well that has just been added to the list of things to do, along with rust fixing and the like...all in good time haha
i wouldn't freak out about it exactly, i had that problem with my first mini, reco gearbox, sometimes i just didn't pull to the right enough when changing up
I have had that prblem before when i first got my mini, btu i have since learnt how to change gears without this problem but this was a completly different issue.
Cheers all
- Brendon
