cLutch shudder
https://www.ausmini.com/forums/viewtopic.php?f=2&t=59657
Author:  i got a mini [ Thu Dec 17, 2009 7:54 pm ]
Post subject:  cLutch shudder
Hey just been driving car and I am getting a real bad shudder when I go to take off and it like shakes the whole car am I in need of a new clutch ??? This was the same clutch out of my old motor
Author:  GT mowog [ Thu Dec 17, 2009 7:59 pm ]
Could be a number of things;-
worn clutch,
broken diaphram,
worn primary gear bushes,
oil on the clutch,
flywheel loose,
broken drive strap (on the flywheel)
Author:  i got a mini [ Thu Dec 17, 2009 8:01 pm ]
Will have to pull it off And have a look
Author:  TheMiniMan [ Thu Dec 17, 2009 11:17 pm ]
but it could also be that you`ve always had a "slight" shudder but never took much notice & "drove around" the """Slight""" shudderr,,, BUT NOW!!! Maybe the engine mount(s) has/have broken? Maybe?
hey,,, it coud still be the clutch problem but if your engine mounts are stuffed it will shudder like S h! T :-)
Author:  drmini in aust [ Fri Dec 18, 2009 7:17 am ]
Could also be a rubbish `cardboard' aftermarket clutch plate. I had that prob on the wife's Mini when bought.
Author:  kaka [ Fri Dec 18, 2009 8:49 am ]
If it clunks a few times as your turning it off could be the loose flywheel.
Author:  i got a mini [ Fri Dec 18, 2009 9:17 pm ]
Nope no clunking at all but is hard to get into first when trying to take off or when changing down gears get back into 2nd
