It is currently Thu Jul 31, 2025 8:24 am
 Post subject: cLutch shudder
PostPosted: Thu Dec 17, 2009 7:54 pm
Hey just been driving car and I am getting a real bad shudder when I go to take off and it like shakes the whole car am I in need of a new clutch ??? This was the same clutch out of my old motor
PostPosted: Thu Dec 17, 2009 7:59 pm
Mods rock!
Could be a number of things;-
worn clutch,
broken diaphram,
worn primary gear bushes,
oil on the clutch,
flywheel loose,
broken drive strap (on the flywheel)
PostPosted: Thu Dec 17, 2009 8:01 pm
Will have to pull it off And have a look
PostPosted: Thu Dec 17, 2009 11:17 pm
but it could also be that you`ve always had a "slight" shudder but never took much notice & "drove around" the """Slight""" shudderr,,, BUT NOW!!! Maybe the engine mount(s) has/have broken? Maybe?
hey,,, it coud still be the clutch problem but if your engine mounts are stuffed it will shudder like S h! T :-)
PostPosted: Fri Dec 18, 2009 7:17 am
Could also be a rubbish `cardboard' aftermarket clutch plate. I had that prob on the wife's Mini when bought.
PostPosted: Fri Dec 18, 2009 8:49 am
If it clunks a few times as your turning it off could be the loose flywheel.
PostPosted: Fri Dec 18, 2009 9:17 pm
Nope no clunking at all but is hard to get into first when trying to take off or when changing down gears get back into 2nd
Users browsing this forum: lomin and 86 guests
