It is currently Tue Jul 22, 2025 2:56 am
 Post subject: timing chain
PostPosted: Tue Mar 22, 2005 9:02 pm
How much sideways movement should there be in a timing chain?
My original 998's chain seemed to have sh!tloads of movement.... :?
PostPosted: Tue Mar 22, 2005 9:03 pm
Go Double or replace the chain..It maybe an Idea to check for worn sprokets :!:
best to replace it :)
get a double row one if so :wink:
PostPosted: Tue Mar 22, 2005 9:15 pm
yea I am going ot replace....I just wanted to know if that was normal.
Double sounds good.
PostPosted: Tue Mar 22, 2005 9:39 pm
NO, It should have pretty minimal movement. Too much movement and the timing would be all over the shop. Variable cam timing in a bad way!
Double row is the way to go. $7 for the chain. Kazjim may have one left. Thats where i got mine for th clubby, when i get round to it.
Aaron
PostPosted: Tue Mar 22, 2005 9:46 pm
Best way to check is Flex it between both hands at each end...Like a Wobbel Board...(I don't Know but it works)...Or Close the sides to gether, Eye Level and see how much the chain flex..Should not be to much for a good chain.... :arrow: Measurment :?:
I think you may have to by one anyway..re-assurance Things :?
PostPosted: Tue Mar 22, 2005 9:51 pm
i reckon the movement of mine was about 15-20mm all up, from one side to the other! :shock:
I knew straight away it wasn't right....
Yes, the motor ran like a dog!!!!!
PostPosted: Tue Mar 22, 2005 9:54 pm
If buying duplex chain, it is all crap these days ( read.. loose) except the endless Iwis race chain. That is good stuff but at around $60 it better be. If you can get it.:wink:
I run a toothed belt drive, but even they are made in China now and are crap too- very flimsy. So I put the old Dayco one back on until I get some decent kevlar race ones from the states. 8)
PostPosted: Tue Mar 22, 2005 10:00 pm
Whats the next best then..Myself $60 is fine But for someone else :?:
PostPosted: Tue Mar 22, 2005 10:03 pm
Not much to choose. I would have thought the AE chain would be tighter than it is.
I used to get Renolds duplex chain from work years ago- now that was good chain! and cheap toooo..... :lol:
PostPosted: Tue Mar 22, 2005 10:04 pm
What was the chain we saw resently :?
PostPosted: Tue Mar 22, 2005 10:06 pm
AE- you still have the box.. :lol:
PostPosted: Tue Mar 22, 2005 10:07 pm
Nope all clean now :?
PostPosted: Wed Mar 23, 2005 1:13 pm
II run a toothed belt drive, but even they are made in China now and are crap too- very flimsy. So I put the old Dayco one back on until I get some decent kevlar race ones from the states. 8)
How are you going to source the belts? I need one as well. Did you find a number? I haven't been able to chase it up due to not being able to drive for six weeks after my op.
Chris
Everything I like is either
PostPosted: Wed Mar 23, 2005 3:11 pm
there was SFA movement in my duplex chain.. my single had 30+mm freeplay.. that was awesome for timing. my motorbike chain doesnt even have that much (25mm)
Expert in training
