Shocks with Hydro
https://www.ausmini.com/forums/viewtopic.php?f=2&t=5975
Author:  Matt68 [ Fri Apr 01, 2005 9:01 am ]
Post subject:  Shocks with Hydro
Hello again!
Instead of stealing the other thread on shocks I thought I'd start a separate one!
I'm putting shocks on to the front of my 68 deluxe, I have everything I need, apart from the shocks themselves. Has anyone else done this mod, and which shocks would they reccomend for this?
Matt
Author:  drmini in aust [ Fri Apr 01, 2005 9:10 am ]
My hydro has had them on for years.
I used Pedders, find them good- but any stocko Mini front shock will do. You don't need heavy damped ones or adjustables, as you are just adding a bit to the hydro's existing damping. :wink:
Author:  Matt68 [ Fri Apr 01, 2005 9:15 am ]
Thanks doc,
I thought the stockers would be the way to go. Just the standard pedders? (OK I don't even know if they make different ones)
Any other advice for this mod?
Matt
Author:  drmini in aust [ Fri Apr 01, 2005 9:21 am ]
Id go with stock Pedders or Gabriel Red Riders.
Use the brackets off a Clubbie- clean the muck out of the mounting hole threads of the car(1/4" UNF),.
Re the top arm shock bolt- you can either drill the arm out to 3/8" (they are bloody hard, though)- or, do what I did with mine and Chong's- use an 8mm x100 Unbrako cap head bolt. And then make a 3/8 x 8mm steel bush to go inside the lower shock bush. I've had no trouble with this method, it's been on the car 9 years now. :wink:
Author:  Matt68 [ Fri Apr 01, 2005 9:39 am ]
Thanks Doc,
I've got new (reco) top hydro arms, so I was going to take em to a friend who has machining tools (he owns and runs an engine reconditioners) and get him to drill them to 3/8".
Thanks again!
Matt
Author:  scotty [ Fri Apr 01, 2005 11:54 am ]
i've got them on mine and they work fine, but I have found that when you take some fluid out and lower it a bit that it takes a few k's for the shocks to settle in properly. Nothing I'm sure a bit of WD40 can't fix :D .
Btw. I know that you only have two valves (left - right) but the rear of mine sits really high (looks like someone gave it a 'wedgee'!!!) Does anyone have a remedy???
Author:  drmini in aust [ Fri Apr 01, 2005 12:14 pm ]
Hydros are designed to sit a bit higher at the back, so you can carry passengers.... :lol:
But, probably your rear `helper' springs are now weak from old age- they actually hold the rear down and displace fluid to the front. :wink:
Author:  scotty [ Fri Apr 01, 2005 10:44 pm ]
Cheers doc. Are they hard or expensive to replace? Will give me something to tinker with on Saturday :D
Author:  drmini in aust [ Sat Apr 02, 2005 6:41 am ]
Not once you let all the fluid out and move the fuel tank....!
If buying spare helper springs pick the shortest ones out of the pile.. :wink:
