It is currently Tue Jul 22, 2025 12:13 pm
 Post subject: Dip stick question
PostPosted: Tue Dec 22, 2009 11:27 am
Is there a difference in lengths of dip sticks between the ones that sit straight in the block and those used with the plastic tube? - If so what is it?
PostPosted: Tue Dec 22, 2009 12:49 pm
None sit straight in the block. They either use the plastic or steel tube.
Length differences I'm not too sure
PostPosted: Tue Dec 22, 2009 1:10 pm
and if you dont have the tube in place, you get oil all over your engine bay :?
big thanks to Scott for fixing that issue. :D
PostPosted: Tue Dec 22, 2009 1:23 pm
Got the tube :wink: just thought the dip stick looked a little 'short' and thought maybe it went straight in the block.
PostPosted: Tue Dec 22, 2009 4:15 pm
PostPosted: Tue Dec 22, 2009 4:28 pm
803, 850, 950 & 997 A series engines, the dip stick goes straight into the block with a small felt seal on the end of the dip stick
A+ Engines also have the dip stick going straight into the block, they have a rubber seal.
Have a Nice Day.
PostPosted: Tue Dec 22, 2009 5:02 pm
Yes, all the pre A+ blocks do use / need a tube, however the A+ do not use any tubes, the dip stick goes staight in to the block. The Dip Sicks for the A+ are also little different at the seal (shape of it).
PostPosted: Tue Dec 22, 2009 6:00 pm
The one on my A+ 1275 SPI motor sits straight in the block with no tube :?
Cheers Pete
PostPosted: Wed Dec 23, 2009 7:51 am
well there you go. Learn something everyday. I have never had any experience with A+ engines and with 803s, 950s (mini engines? No) 850s & 997s well I have never bothered to look. :)
PostPosted: Wed Dec 23, 2009 8:09 am
Hey, learning = 8).
