Dip stick question https://www.ausmini.com/forums/viewtopic.php?f=2&t=59761 |
Author: | Wombat [ Tue Dec 22, 2009 11:27 am ] |
Post subject: | Dip stick question |
Is there a difference in lengths of dip sticks between the ones that sit straight in the block and those used with the plastic tube? - If so what is it? |
Author: | TK [ Tue Dec 22, 2009 12:49 pm ] |
None sit straight in the block. They either use the plastic or steel tube. Length differences I'm not too sure |
Author: | Drexxle [ Tue Dec 22, 2009 1:10 pm ] |
and if you dont have the tube in place, you get oil all over your engine bay ![]() big thanks to Scott for fixing that issue. ![]() |
Author: | Wombat [ Tue Dec 22, 2009 1:23 pm ] |
Got the tube ![]() |
Author: | AEG163job [ Tue Dec 22, 2009 4:15 pm ] |
Drexxle wrote: and if you dont have the tube in place, you get oil all over your engine bay
Author: | 850man [ Tue Dec 22, 2009 4:28 pm ] |
TK wrote: None sit straight in the block. They either use the plastic or steel tube.
Length differences I'm not too sure ???? 803, 850, 950 & 997 A series engines, the dip stick goes straight into the block with a small felt seal on the end of the dip stick A+ Engines also have the dip stick going straight into the block, they have a rubber seal. |
Author: | GT mowog [ Tue Dec 22, 2009 5:02 pm ] |
Length differences I'm not too sure Yes, all the pre A+ blocks do use / need a tube, however the A+ do not use any tubes, the dip stick goes staight in to the block. The Dip Sicks for the A+ are also little different at the seal (shape of it). |
Author: | EST-071 [ Tue Dec 22, 2009 6:00 pm ] |
Length differences I'm not too sure The one on my A+ 1275 SPI motor sits straight in the block with no tube ![]() Cheers Pete |
Author: | TK [ Wed Dec 23, 2009 7:51 am ] |
well there you go. Learn something everyday. I have never had any experience with A+ engines and with 803s, 950s (mini engines? No) 850s & 997s well I have never bothered to look. ![]() |
Author: | GT mowog [ Wed Dec 23, 2009 8:09 am ] |
TK wrote: well there you go. Learn something everyday. I have never had any experience with A+ engines and with 803s, 950s (mini engines? No) 850s & 997s well I have never bothered to look.
![]() Hey, learning = ![]() Cheers |
