It is currently Sat Jul 26, 2025 6:20 pm
PostPosted: Mon Dec 21, 2009 10:49 pm
i can check it it's dark out side now..
but the clutch seems softer then it was before. i have to double pump to get into first & reverse then when driving it seems fine..
Everything is new & re-coned including gearbox.
do you think maybe needs re bleeding? it feels like there is little travel in the clutch like really soft then firm 3/4 way down.
understand?
PostPosted: Mon Dec 21, 2009 10:56 pm
NAV-MAN
Could be a number of things Nick, has it been gradual or was it a sudden change?
PostPosted: Mon Dec 21, 2009 11:02 pm
Gradual then as far as i can remember a sudden softness.
PostPosted: Mon Dec 21, 2009 11:28 pm
NAV-MAN
Sounds like it might be in need of a bleed.
How mechanically able are you?
PostPosted: Mon Dec 21, 2009 11:33 pm
yes easy.
that's what i thought nav.
I did it maybe 2 months ago the same time i did the brakes & it was all perfect!
only sorta happened the end of last week.
any reason why it would do that?
can air seep in? i made sure all the nips were locked off after i was done.
PostPosted: Mon Dec 21, 2009 11:37 pm
NAV-MAN
NG wrote:
yes easy.
Air could seep in through the master cylinder when you pump it.
I'd check the clutch arm at the ball end where it goes into the wok and see if it is broken down there
PostPosted: Mon Dec 21, 2009 11:49 pm
ok cool..
so does that mean a new cylinder? if the ball is broken?
ill bleed it first and see how i go.
PostPosted: Mon Dec 21, 2009 11:52 pm
NAV-MAN
NG wrote:
ok cool..
The balls are bent or broken too easily these days. I'd check that 1st eliminate that as its a no cost sneak a peak
PostPosted: Tue Dec 22, 2009 1:18 am
NG wrote:
ok cool..
Nick the ball Nav is referring to is on the end of the clutch arm, just inside the end of the clutch housing.
Tim.
tim
PostPosted: Tue Dec 22, 2009 11:18 am
yeh it's a verto clutch it looks all good down there.
ill bleed it up today & see how she go's :)
PostPosted: Tue Dec 22, 2009 11:19 am
NAV-MAN
Ok good luck with it.
 Post subject: clutch problem
PostPosted: Tue Dec 22, 2009 4:39 pm
Mate been there. Think it might be a clutch master cylinder. Mine was doing exactly the same, new master cylinder now no problems whatsoever.
Good luck mini74.
PostPosted: Thu Dec 24, 2009 12:14 pm
had to re bleed it.. works great again. :D
